MR2 SpyderChat banner
Time for a guessing game...
32K views 20 replies 11 participants last post by  cyclehead
#1 · (Edited)
Meet Spyder #9, or as I call her "Betty White"
Spyder #8 I picked up with white body panels, and the wife was infatuated with having a white Spyder since. So I found this one.
Wheel Tire Car Automotive parking light Vehicle
Car Vehicle Motor vehicle Automotive design Car seat cover
Wheel Car Tire Land vehicle Vehicle
She was on Copart in Florida with flood damage.
The original plan was to simply rob the white body panels off of her and put them on the wife's current Spyder, #5. But plans changed when she reached my garage and I started shaking the salt water rust and problems out of her.
Car Wheel Tire Vehicle Hood
Automotive parking light Car Vehicle Vehicle registration plate Tire
Car Vehicle registration plate Vehicle Land vehicle Wheel
Automotive parking light Car Land vehicle Wheel Tire
Last pics are when I brought her up here into the Midwest and got her a fresh full detail on the exterior and interior, and a ceramic coat on the exterior.
Now I've only revealed the mileage to a few people on Facebook and discord, so, who can guess the mileage of this white 2001 MR2 Spyder. (And if you already know, no telling :p )
See less See more
7
#10 ·
Tire Wheel Crankset Automotive tire Motor vehicle
Tire Wheel Automotive tire Motor vehicle Tread
Tire Wheel Automotive tire Automotive lighting Vehicle
Automotive tire Motor vehicle Automotive lighting Bumper Rim
Bridle Horse tack Bit Motor vehicle Helmet
Automotive tire Tire Tread Saw Wood
Personal protective equipment Art Auto part Button Wood
So I had a picture of the starter somewhere... Not sure where it went but the first time I tried starting her up the power steering pump kicked on right away with the key on, also could not read anything with my OBD2 reader, so the ECU was fried from the saltwater. Attempted to engage the starter, you could hear the battery draw and the solenoid inside of the starter click, however no rotation. I had a spare starter from a parts car laying around, I removed the old starter and found that it was completely seized, the arm would not extend and I could not spin the gear by hand or with a pliers. Put in the other starter, starter engaged with the key, plugs out, no moisture found inside of the engine.
Changed the oil on both the transmission and engine, both oils were very very fresh, no water content. No evidence of water making it past the air filter, so I didn't bother removing the intake to check for water.
Had two ECUs flashed by Paul Hibbs via the spyder chat Facebook group, reprogrammed the keys to the ECU, engine fired after the first second of cranking... Friggin nuts...
Had lots of running noise though, one of the running noises being the throwout bearing. I changed that in one night except I kind of buggered up the passenger side CV shaft seal which I am going to try and replace tonight or tomorrow. The other noise once I fixed the TOB noise was the tensioner pulley. After replacing that the engine runs as quiet as it can be.
Put on a header that I gutted the pre-cats out of, planned on selling the 21k mile header from the car to someone who may need it to pass inspection. While I had the header off to remove the transmission and everything I found water sitting in the midpipe, did the right thing and just shoved a vacuum down the mid-pipe for a few minutes and sucked out a decent amount of water.
The exhaust does have some rust spots pretty much everywhere, and while the car was running at the beginning was putting out some rusty water, but that seems to have subsided.
Hardest part about this car is my wife is very opinionated... She did not like the peanut butter interior and soft top right away, wanted me to change over the top and interior from Spyder #5.
Thankfully now she's kind of come around on it and is willing to keep the peanut butter around. Hopefully part of the reasoning is because I told her it's pretty much sacrilege to take the car apart as she sits and change her from OEM with so few miles on her.
#13 ·
I planned to spray down all the connections with some spray and let them sit for a while but the cleaning spray I ordered hasn't arrived yet. The water level definitely reached the starter and ECU level obviously. But I have sprayed the fuse and relay boxes in the engine bay, the front bay upper fuse and relay boxes didn't have any evidence of salt water in them.
It's definitely on my to do list, but currently putting a new passenger side CV seal in and buttoning her up a bit and bringing her to my storage shed/shop to let the wife's Camry back into the garage before we get snowed in again.
#14 ·
I don't know what the spray is that you are thinking of, but I would wash the salt out. If you don't, then whenever you have a humid day the corrosion is going to start up again. If I need to do a fast wash and dry, I use alcohol. If you don't have a time limit, then water and air dry should be just fine.
I strongly recommend keeping the battery disconnected until your salt water remediation is done. Most of the water related damage to electronics happens when people turn the gadget on to see if it still works.
#15 ·
I used an alcohol based electronics cleaner in the engine bay, someone recommended a specific type of marine alcohol-based electronics cleaner that I'm waiting to arrive. I drove the car last night out to the storage building for Cold storage for now. I haven't noticed any battery draw currently
#18 ·
For a quick update beins the thread is revived somewhat.
Tire Wheel Car Land vehicle Vehicle
Pulled her out of storage last night from the in-laws. The battery was dead because I wasn't able to disconnect the battery over the winter because the cable that leads to the rear deck lid latch is seized. Knocked out the upper grill to reach my hand in and pop the deck lid free. Got it jumped and drove home and put on a tender.
Drove it for half an hour today around town, she is about to roll over to 23,000 mi. Needs an alignment and while driving car was shaking due to some wheel flat spots... Decided to look at the date code as I was sitting still at a friend's place.
And I think these are the original tires...
Tire Wheel Vehicle Automotive tire Tread
Tire Wheel Automotive tire Synthetic rubber Tread
Automotive tire Rim Personal luxury car Automotive design Car
Date codes of 2001, which is this car's model year.
#20 ·
Tend to agree. Which is why I'm trying to get the wife to put in one of the center console arm wrests that will save on the center console breaking... Wife in all her closed mindedness goes nooooooooope. If it ain't OEM it's not in the options
Top
